That’s what the issue is. Did you do an import from mbox? Is it installed for some other reason?
You can either comment it out or modify that template as I mentioned earlier. If you do, you’ll need to do a git stash before you can upgrade.
Yes, l used mbox when first moving from our mailing list!
Thanks guys, I will clean up my container and try to rebuild.
Good luck, hope you can get it back online soon!
Hey @Falco – is this on the map?
I also was unable to make the postgres templates work because of this bug: Problem with postgres upgrade
Yes, I should be able to address it next week.
Did it get into the base image version bump the just got accepted?
Can you also take a look at bash tab completion for launcher + discourse-setup by pfaffman · Pull Request #676 · discourse/discourse_docker · GitHub? I would give to have it on all of the sites I touch.
Fixed 10h ago by @schleifer
Maybe open a topic to discuss and demo that?
This topic was automatically closed after 4 days. New replies are no longer allowed.
