Arch Linux - service-start-limit-hit
Hello Everyone,
I am trying to install discourse on the computer I am typing this on, which is currently running Arch Linux. I followed the instructions and just ran ./discourse-setup. I set up all the necessary features, output:
# ./discourse-setup
which: no docker.io in (/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
The configuration file containers/app.yml already exists!
. . . reconfiguring . . .
Saving old file as app.yml.2019-03-12-191642.bak
Stopping existing container in 5 seconds or Control-C to cancel.
Device "docker0" does not exist.
Cannot connect to the docker daemon - verify it is running and you have access
Found 8GB of memory and 2 physical CPU cores
setting db_shared_buffers = 2048MB
setting UNICORN_WORKERS = 4
containers/app.yml memory parameters updated.
Hostname for your Discourse? [<I am not showing you for privacy>]:
Email address for admin account(s)? [<I am not showing you for privacy>]:
SMTP server address? [<I am not showing you for privacy>]:
SMTP port? [587]:
SMTP user name? [<I am not showing you for privacy>]:
SMTP password? [<I am not showing you for privacy>]:
Optional email address for setting up Let's Encrypt? (ENTER to skip) [me@example.com]:
Does this look right?
Hostname      : <I am not showing you for privacy>
Email         : <I am not showing you for privacy>
SMTP address  : <I am not showing you for privacy>
SMTP port     : 587
SMTP username : <I am not showing you for privacy>
SMTP password : <I am not showing you for privacy>
ENTER to continue, 'n' to try again, Ctrl+C to exit:
Configuration file at  updated successfully!
Updates successful. Rebuilding in 5 seconds.
Building app
I ran systemctl status docker, and this was the output:
# systemctl status docker
● docker.service - Docker Application Container Engine
   Loaded: loaded (/usr/lib/systemd/system/docker.service; disabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Tue 2019-03-12 19:09:43 PDT; 11min ago
     Docs: https://docs.docker.com
  Process: 6070 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILURE)
 Main PID: 6070 (code=exited, status=1/FAILURE)
Mar 12 19:09:43 <hostname> systemd[1]: docker.service: Service RestartSec=100ms expired, scheduling restart.
Mar 12 19:09:43 <hostname> systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Mar 12 19:09:43 <hostname> systemd[1]: Stopped Docker Application Container Engine.
Mar 12 19:09:43 <hostname> systemd[1]: docker.service: Start request repeated too quickly.
Mar 12 19:09:43 <hostname> systemd[1]: docker.service: Failed with result 'exit-code'.
Mar 12 19:09:43 <hostname> systemd[1]: Failed to start Docker Application Container Engine.
Here is the snippet of journalctl -xe:
-- Subject: A stop job for unit docker.socket has begun execution
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- A stop job for unit docker.socket has begun execution.
-- The job identifier is 6080.
Mar 12 19:09:43 <hostname> systemd[1]: Starting Docker Socket for the API.
-- Subject: A start job for unit docker.socket has begun execution
-- A start job for unit docker.socket has begun execution.
Mar 12 19:09:43 <hostname> systemd[1]: Listening on Docker Socket for the API.
-- Subject: A start job for unit docker.socket has finished successfully
-- A start job for unit docker.socket has finished successfully.
-- Subject: Unit failed
-- The unit docker.service has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit docker.service has failed
-- A start job for unit docker.service has finished with a failure.
-- The job identifier is 6011 and the job result is failed.
Mar 12 19:09:43 <hostname> systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'.
-- The unit docker.socket has entered the 'failed' state with result 'service-start-limit-hit'.
Please assist me. I also changed my app.yml port to 1209.
Looks to me like docker is refusing to start on your system, I would recommend starting by figuring out how to get docker working
May you help me with that, or do I need to ask somewhere else?
Probably best ask on docker forums or arch linux forums
Restart your computer :wink:
