Site Not Opening, How Can I Know What's Wrong?
Hi,
Please https://forum.netdivo.com is not opening
How can I know what is wrong?
The server is running and I have restarted it several times.
Your Ping goes to request timed out.
This can be due to a firewall preventing connections to your server or discourse not running.
Can you ssh into your server and do
cd /var/discourse
docker ps
It will give you an output to verify if your discourse container is actually running or not.
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/r
un/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.39/containers/json: dial unix /va
r/run/docker.sock: connect: permission denied
Pls, how do I resolve this?
Are You performing this as root? If not then try
sudo docker ps
If it still reports the same issue then Your docker is probably not running. You’ll need to find out how docker was installed to restart it.
running it as root did not throw the error.
See what i got in the screenshot below
Discourse isn’t running try this:
cd /var/discourse
./launcher start app
this returned:
starting up existing container
  • /usr/bin/docker start app
    Error response from daemon: driver failed programming external connectivity on endpoint app (9076151599bb0371571888de949fc4c3e747160792902ea5c483536fabaf99cc): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
    Error: failed to start containers: app
docker info :
/var/discourse# docker info
Containers: 1
Running: 0
Paused: 0
Stopped: 1
Images: 9
Server Version: 18.09.2
Please run
netstat -alpn | grep 80
And share your output
Ps: You need to update docker
see output :
/var/discourse# netstat -alpn | grep 80
tcp6       0      0 :::80                   :::*                    LISTEN      911/apache2
tcp6       0      0 172.26.13.42:80         213.95.35.221:25030     SYN_RECV    -
tcp6       0      0 172.26.13.42:80         213.95.35.221:27615     SYN_RECV    -
tcp6       0      0 172.26.13.42:80         213.95.35.221:6406      SYN_RECV    -
tcp6       0      0 172.26.13.42:80         213.95.35.221:48296     SYN_RECV    -
unix  2      [ ACC ]     STREAM     LISTENING     19680    816/dockerd          /var/run/do
cker/metrics.sock
unix  3      [ ]         STREAM     CONNECTED     17604    809/systemd-logind
unix  2      [ ]         DGRAM                    18293    809/systemd-logind
unix  2      [ ]         DGRAM                    18283    806/rsyslogd
unix  3      [ ]         STREAM     CONNECTED     18299    809/systemd-logind
unix  3      [ ]         STREAM     CONNECTED     18099    816/dockerd
You have apache2 running on Your server, it needs to be stopped and uninstalled before you could start discourse docker.
Try
service apache2 stop
apt purge apache* -y
cd /var/discourse
thanks but the purge command threw this error :
Append sudo to the command e.g.:
sudo -i
cd /var/discourse
Wow! It works. Site back online!
happy gif
Thanks so much!
