Tenho uma instalação padrão que acabei de atualizar e que está falhando devido a um problema de fuso horário. Acho que pode ser apenas um usuário, mas ainda não tenho certeza.
Era apenas para um usuário. Quando fui ao perfil dele, o fuso horário não estava definido. Quando defini o fuso horário, o problema desapareceu.
Started GET "/t/37040.json?track_visit=true&forceLoad=true" for 204.98.75.5 at 2023-03-23 21:36:37 +0000
Processing by TopicsController#show as JSON
Parameters: {"track_visit"=>"true", "forceLoad"=>"true", "id"=>"37040"}
Completed 500 Internal Server Error in 48ms (ActiveRecord: 0.0ms | Allocations: 8345)
ArgumentError (Invalid Timezone: US/Pacific-New)
(eval):82:in `_fast_attributes'
app/serializers/post_stream_serializer_mixin.rb:54:in `block in posts'
app/serializers/post_stream_serializer_mixin.rb:47:in `map'
app/serializers/post_stream_serializer_mixin.rb:47:in `posts'
app/serializers/post_stream_serializer_mixin.rb:18:in `post_stream'
(eval):3:in `_fast_attributes'
app/controllers/application_controller.rb:545:in `render_json_dump'
app/controllers/topics_controller.rb:1242:in `block (2 levels) in perform_show_response'
app/controllers/topics_controller.rb:1232:in `perform_show_response'
app/controllers/topics_controller.rb:187:in `show'
app/controllers/application_controller.rb:414:in `block in with_resolved_locale'
app/controllers/application_controller.rb:414:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
lib/middleware/anonymous_cache.rb:369:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:228:in `call'
Failed to handle exception in exception app middleware : ArgumentError : Invalid Timezone: US/Pacific-New
Rendered text template (Duration: 0.0ms | Allocations: 1)
Started GET "/latest.json" for 172.220.127.141 at 2023-03-23 21:37:00 +0000
Processing by ListController#latest as JSON
EDIT: talvez ele tivesse o fuso horário definido para esse valor inválido? Testei outro usuário com um fuso horário nulo e não houve erro.
