Arvind_Hebbal reports an authentication error (“csrf_detected”) when using a custom OAuth provider with the discourse-oauth2-basic plugin in production mode, noting that session["omniauth.state"] is missing after redirect — though the setup works in development. david asks whether authentication occurs in the same browser and if same_site_cookies was modified; Arvind_Hebbal confirms both are unchanged (default “Lax”). david recommends following the official install guide and notes that custom Docker setups (like Arvind_Hebbal’s, which uses a custom start script) are unsupported in community support. david suggests using the official setup or seeking paid help via the Marketplace if the guide isn’t feasible.
Greetings,
We are trying to deploy discourse forums in production mode. We are using our own oauth provider and hence using discourse-oauth2-basic plugin to enable the same.
We are seeing the following error when login in with our custom oauth provider:
After some debugging, it is seen that the “omniauth.state” is missing in the session after the redirect happens and hence unable to validate the state field in the /auth/oauth2_callback. Any help would be appreciated.
Note: The entire setup is working fine in the development mode
Hello @david we are hoisting discourse using docker containers. The docker file which we are using is discourse_docker/image/base at master · discourse/discourse_docker · GitHub. Since there is no script to start discourse inside docker container we have added a small start script which pre compiles and starts discourse.
RAILS_ENV=production bundle exec rake db:migrate
RAILS_ENV=production bundle exec rake assets:precompile
RAILS_ENV=production bundle exec rails server --binding=0.0.0.0
Unfortunately it is very difficult for us to offer community support here for custom installations. Please try setting up Discourse using the official guide. If you’re not able to do that, maybe someone in the Marketplace could help out for a fee
