Discourse Cookie Store: Omniauth callback sessions are nil
leo.proctor reports that after updating to the tests-passed branch, session values in omniauth_callback_controller.rb are nil, causing CSRF detection failures during OAuth2 callbacks. They identified that session_store was changed from :cookie_store to :discourse_cookie_store, noting that reverting to the old store resolves the issue same site cookies codinghorror asked for input, and eviltrout suggested the user might be working on a branch over 5 months old. leo.proctor clarified that the issue stems from the recent SameSite cookie implementation, which restricts third-party cookie sharing; they resolved it by adding exceptions for their SSO/OAuth2 provider while keeping security features intact.
In my custom oauth2 login I’m saving some session values. It was working fine till I recently pulled the latest code from branch tests-passed and noticed that session is always nil in omniauth_callback_controller.rb
def complete
auth = request.env[“omniauth.auth”]
auth[:session] = session # it doesn’t contain my session value
Then i found out session_store was changed in latest pull
Discourse::Application.config.session_store(
:discourse_cookie_store, #it use to be :cookie_store
key: ‘_forum_session’,
path: (Rails.application.config.relative_url_root.nil?) ? ‘/’ : Rails.application.config.relative_url_root
even it raises csrf_detected failure at callback_phase method at oauth2 strategy file if opts[:provider_ignores_state] is set to true, cuz session[‘omniauth.state’] is nil
elsif !options.provider_ignores_state && (request.params[“state”].to_s.empty? || request.params[“state”] != session.delete(“omniauth.state”))
fail!(:csrf_detected, CallbackError.new(:csrf_detected, “CSRF detected”))
Just to mention, everything works fine if I change it to :cookie_store rather than ':discourse_cookie_store`. is it a bug?
Any ideas here @eviltrout?
Looking at git blame, the :discourse_cookie_store change was 5 months ago. Were you working with a branch that’s over 5 months old? If so I’m not surprised it broke!
「いいね!」 2
It had to do with the recent addition of extra security for cookies same site cookies in discourse, which prevents sharing cookies with third party sites, which is kind of secure. I’m using a bit complex authentication system which involves SSO and OAuth2, where i had to share some cookies with our known authentication server. I added an exception in terms of sharing cookies with this server while perserving same site cookies feature and everything is working fine.
Thanks for response and such an awesome forum application. @codinghorror @eviltrout :grinning:
「いいね!」 4
