Automatisch video's van YouTube-afspeellijsten plaatsen?
I’d like to use RSS Polling to auto-post videos from YouTube playlists, which are in the form: https://www.youtube.com/feeds/videos.xml?playlist_id=ID.
However, the link attributes are the videos themselves, like https://www.youtube.com/watch?v=VID. This means I can’t use these URLs to set the categories by regex, but I could with the source/RSS URLs (each RSS would target a category). This isn’t possible right now, right?
It’s not currently possible. There are some details about the issue here: Discourse-rss-polling: polling YouTube playlist feed.
Ok, so just to be clear: it isn’t possible to use YouTube feeds because they use some custom media tags, right?
However, I’ve seen similar situations to what I described above on blog posts too, where the link from the feed isn’t enough to identify a category, so in these cases it’s not possible to auto-set a category?
Right. I see now that I didn’t answer your initial question:
You should be able to get all feeds that have their link attribute set to the www.youtube.com domain to publish to a category by creating a host record with its domain set to www.youtube.com: Something like this:
I don’t think there is a way to set specific categories based on the playlist’s ID though.
Apparently you can pull in a YouTube channel’s feed with the plugin. Possibly the same approach will work for a playlist. Have a look at this post for details: Automatically post YouTube videos from a certain channel? - #3 by CaptainZac. If you get a chance to try this out, let us know if it works.
