Autocomplete list suggestions
This discussion covers suggestions for improving the autocomplete list design in Discourse. The main points are:
  1. Don suggests using the full width of the autocomplete list on mobile to prevent it from going offscreen, with a CSS code snippet.
  2. Don proposes using pseudo-elements to create top and bottom fading shadows on the autocomplete list, removing the need for a bottom margin. This is demonstrated with code examples and screenshots.
  3. chapoi expresses appreciation for the second suggestion to use pseudo-element shadows, planning to implement it.
The suggestions aim to enhance the autocomplete list’s usability and visual design, particularly on mobile devices and when the list is scrollable or not.
Hello,
First of all thank you so much for the new autocomplete design I really love it. :heart:
I made a little changes what I use on my site.
1. I use the autocomplete list full width on mobile. I think that is a safe thing now because it prevents the list to go out of the screen. It happens on somewhere center. It make a wider view which is good when user have a longer name or has user status available.
.d-editor-textarea-wrapper {
  .autocomplete {
    .mobile-view & {
      max-width: calc(100% - 20px);
      width: 100%;
      left: 10px !important; // override left position calculation
2. On the fadeout list the bottom shadow and margin always visible even if the list is not scrollable. I use the shadow to an :after pseudo instead of -webkit-mask. I added a top and bottom shadow which is slide under the first and last li element. This way I can remove the bottom margin.
.hashtag-autocomplete {
  max-height: 14em;
  &__fadeout {
    -webkit-mask: none;
    &:before {
      content: '';
      position: absolute;
      top: 0;
      width: 100%;
      height: 1.5em;
      background: linear-gradient(
        to bottom,
        rgba(var(--secondary-rgb), 1),
        rgba(var(--secondary-rgb), 0)
    &:after {
      content: '';
      position: absolute;
      bottom: 0;
      width: 100%;
      height: 1.5em;
        to bottom,
        rgba(var(--secondary-rgb), 0),
  &__option {
    &:last-of-type {
      margin-bottom: 0;
    // put it top of the shadows
    &:first-of-type,
    &:last-of-type {
      .hashtag-autocomplete__link {
        position: relative;
        z-index: 1;
hashtag
Love the solution; will implement. :heart:
