Been trying to test this feature on our forum. I tick the box “Automatically wraps images in [grid] tags when 3 or more images are uploaded in the composer.” in Experimental, and nothing happens.
Do I need to reboot the server? I’m on 3.5 beta8, so up to date. Am I missing something?
@pierrox Are you using the rich text editor? If so, please note that image grids aren’t supported there yet (but that work is in progress!) so in the meantime you’ll need to switch to Markdown mode for that.
(Moving us over to a new topic for better visibility…)
Okay, thanks for confirming…I’ll see if I can replicate the issue.
(For the record, the rich text editor is actually far less technically demanding than the Markdown editor…so your community might be a great fit for it!)
Really strange. I tried it on another forum where I have admin privileges and it works as advertised. But on the forum I want to install this, no luck. I even tried the Rich Text Editor option as it worked on the test forum (as long as I kept the editor in Markdown mode).
Nothing specific in /logs and no errors in the JS console.
Is there any other related setting besides Experimental auto grid images? I also reviewed all the modified settings on the instance and didn’t see anything that could interfere with that.
I’d be happy to provide more info it I know where to look
We don’t add spaces before punctuation, but in my repro it didn’t work either. I think in my case the problem is that “Wird hochgeladen” are two words.
We activated it - it’s the summer season, and on our forum (old VW campers), people throw in tons of holiday pix, so having the gallery by default is a must.
I’ll activate the new Reply box when it’s fully compatible with the auto-gallery tags. Talking about this one, it would be neat if when it’s activated forum-wide, it defaults to the new WYSIWYG setting instead of Markdown as our users probably won’t notice the new switch even if we tell them!
