Automatically Apply Badges to Group Members (in Hosted Version)
Users discuss automatically applying badges to group members on the hosted Discourse platform. apautler seeks a solution for their hosted plan, as SQL queries are not available. sam clarifies that SQL can be enabled upon request, but scombs and others share SQL code to grant badges based on group membership, noting it runs via a daily scheduler. Cozdabuch asks about code differences, which scombs and riking confirm are minor, involving naming and formatting. paulrudy asks if Discourse will add native support for automatic badge granting via groups. simon clarifies that custom badge SQL is no longer enabled for Standard or Business plans, so users must use the API or manual methods instead.
I’d like to automatically apply certain badges to users in certain groups. In searching the forum, it appears this may be possible via SQL queries, etc. We are on the hosted plan, so that is not possible. In talking with Discourse support, it appears a solution might be to make an app/script that uses the API to apply the badge to users in a groups. Two questions with this:
  1. Has someone done this already and would be willing to share?
  2. How would I implement an app/script that uses the API within the hosted forum setup?
It is possible on hosted plans, just let us know by emailing team@discourse.org and we can enabled them.
@sam Gotcha. What do you think is the better option though? Is it dangerous to begin making SQL queries from within the hosted platform? Makes me a bit nervous because there are other admins in our account and I worry if they accidentally do something in the currently hidden SQL area, it could seriously mess up our database.
If this is a once off I would just make the badges, let us know when you are done and then disable badge SQL.
Should be fine.
I think it makes sense to extend groups to, optionally, automatically grant a badge, so SQL is not involved.
You can also do this via the API but it would require running a regular job on your end.
Is there a way to paste an example code that we can upload on our site?
Is user1 is added to groupX, award badgeX
Simple, nothing more to it
Here is the badge SQL, just replace your_group_name
select user_id, created_at granted_at, NULL post_id
from group_users
where group_id = (
  select g.id from groups g where g.name = 'your_group_name'
This will run via the scheduler correct? It is not triggered be the group add, but just runs daily and awards based on group membership?
In the badge settings you need to set the trigger to daily and select the option for revocation daily
@scombs, I had posted in another thread, and someone responded almost at the same time. The code is slightly different. Do you know what the difference would be?
main difference is: gu. vs g.
Other poster’s code:
SELECT gu.user_id, gu.created_at AS granted_at, null AS post_id
FROM group_users AS gu
WHERE gu.group_id = ( SELECT id FROM groups WHERE name ilike 'InsertTheTeamNameHere' )
is there any practical difference?
I’m a complete novice at this, and I just want to give the site owner the code to copy/paste so he doesn’t have to modify it at all.
btw, the group name we are using is: Confirmed_ST_User
Not sure. I saw the other post too.
Here is the howto with the code
Should be the same as I explained there. :slight_smile:
thanks @scombs @pfaffman!! :grinning:
The code is identical, just some renaming, capitalization, and formatting differences.
J’espère qu’il est acceptable de raviver ce sujet pour demander : Y a-t-il une probabilité que les groupes soient étendus pour inclure l’option d’attribuer automatiquement un badge, sans SQL ?
Je tiens simplement à ajouter une note pour indiquer que nous ne pouvons plus activer le SQL de badges personnalisés pour les sites hébergés sur nos plans Standard ou Business. Vous pouvez toujours créer des badges personnalisés, mais vous devrez soit les attribuer manuellement, soit les attribuer via l’API Discourse. Vous trouverez des détails sur l’attribution d’un badge via l’API ici : Grant a custom badge through the API.
