[v2.0.0.beta5 +63]
Avatars occasionally don’t show up.
I can confirm this is happening on Meta right now as well.
We’re aware and are working on a fix.
Fix has been committed. This was a regression from PERF: Don't join on shared drafts unless you have to · discourse/discourse@efedd97 · GitHub, which has since been revereted. If you updated your site in the last 2 hours you’ll need to update again. Fix is deploying to Meta right now, should be done in the next few minutes.
Isso parece não ter relação. Você pode abrir um tópico separado em Contribute > UX para isso?
yes I will, going to update and confirm it still occurs, happened at same update
it’s fixed now. Thanks!
[v2.0.0.beta5 +66]
This topic was automatically closed after 118 minutes. New replies are no longer allowed.
