Hi, I am trying to get avatars to show up on my plugin, but when I pull the avatar_template its shows up like this…
src=“/user_avatar/sitename/natasha/{size}/630932_2.png”
I think it has something to do with size variable ![]()
If you replace the {size} portion of the string with a number it should generate the avatar.
You could perhaps create a computed property, that takes the avatar_template and replaces it with a number like:
@discourseComputed("user.avatar_template")
avatarSrc(avatarTemplate) {
return avatarTemplate.replace("{size}", "75");
and then call that in your template:
<img src={{avatarSrc}} alt="the profile photo of the user"/>
Awesome! That totally worked. Thank you so much! ![]()
