שחזור הגיבוי נכשל עקב סיומת הקובץ .tar לעומת .tar.gz
סיכום מבוסס בינה מלאכותית
A user, Ramith_Hettiarachchi, reports a failed backup restore due to a .tar file extension, which was later corrected to .tar.gz. Gerhard explains that the issue may stem from a non-standard tar format, possibly created on macOS, and suggests using the --format ustar option or creating a new backup in a Discourse Docker container. Ramith_Hettiarachchi confirms the backup was downloaded from a previous hosted instance and had a .tar extension. Another user, Martim, experiences a similar issue but later resolves it, noting that the restore failed due to a missing dump.sql.gz file. Rishabh checks if Martim resolved the issue, to which Martim confirms the restore succeeded after posting.
Hi can you please let me know what might be the issue, restoring the backup.
Backup was created on 2019-09-03
Any tips would be highly appreciated :heart:
> root@discourse-beta-ubuntu-s-1vcpu-1gb-sgp1-01-app:/var/www/discourse# discourse restore entc-bme-forum-2019-09-03-194746-v20190603134013.tar.gz
> Starting restore: entc-bme-forum-2019-09-03-194746-v20190603134013.tar.gz
> [STARTED]
> 'system' has started the restore!
> Marking restore as running...
> Making sure /var/www/discourse/tmp/restores/default/2020-03-28-174121 exists...
> Copying archive to tmp directory...
> Unzipping archive, this may take a while...
> EXCEPTION: File exists - /shared/tmp/restores/default/2020-03-28-174121/PaxHeader
> /usr/local/lib/ruby/2.6.0/fileutils.rb:525:in `block in mv'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:1557:in `block in fu_each_src_dest'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:1566:in `block in fu_each_src_dest0'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:1564:in `each'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:1564:in `fu_each_src_dest0'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:1555:in `fu_each_src_dest'
> /usr/local/lib/ruby/2.6.0/fileutils.rb:520:in `mv'
> /var/www/discourse/lib/compression/strategy.rb:41:in `strip_directory'
> /var/www/discourse/lib/backup_restore/backup_file_handler.rb:70:in `decompress_archive'
> /var/www/discourse/lib/backup_restore/backup_file_handler.rb:22:in `decompress'
> /var/www/discourse/lib/backup_restore/restorer.rb:42:in `run'
> script/discourse:143:in `restore'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/base.rb:485:in `start'
> script/discourse:284:in `<top (required)>'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
> /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
> /usr/local/bin/bundle:23:in `load'
> /usr/local/bin/bundle:23:in `<main>'
> Trying to rollback...
> There was no need to rollback
> Cleaning stuff up...
> Removing tmp '/var/www/discourse/tmp/restores/default/2020-03-28-174121' directory...
> Unpausing sidekiq...
> Marking restore as finished...
> Notifying 'system' of the end of the restore...
> Finished!
> [FAILED]
> Restore done.
First there was an issue the archive being a .tar file, but i recompressed to .tar.gz
Why did you need to make changes to the backup file created by Discourse? Did you create manually create the tar file (on MacOS)? I’ve seen reports where it uses a different tar format which causes problems during decompression.
You might need to create a new tar file with the --format ustar option or, even better, create a new backup directly in a Discourse Docker container.
i downloaded the backup from my previous hosted discourse months back.. when I located it, it was having the .tar extension (i have no clue why - I saw my emails had .tar.gz)
I will try your suggestion!
Thanks a lot @gerhard!
I’m facing the same issue and tried this. The file uploads fine, but restoration can’t find the DB dump:
[2025-01-23 18:39:45] EXCEPTION: No such file or directory @ rb_check_realpath_internal - /var/www/discourse/tmp/restores/default/2025-01-23-183945/dump.sql.gz
Any suggestions? Thanks
Hey Martim,
I see your new topic Locked out of my forum after restore, does that mean you were able to navigate this specific issue succesfully?
It does! Sorry, I thought I had deleted my comment as I managed to restore shortly after.
