Backup restored and images are broken
Hi all,
I’m pretty new to Discourse but I’m already in love with this awesome platform.
I installed the docker version on a VPS and everything was working fine with Nginx as a reverse proxy with certbot.
I had to format the VPS, now with the same configuration, I cannot see the images anymore. I have read that is a common problem but I can’t figure out how to fix it.
https://forumstatale.it/t/vignette-e-meme-storici/22
In the previous installation, I had a warning concerning mixed content between https and https but I fixed it simply removing the images that I’ve uploaded before activating the https.
I could do the same right now since the forum is new, but I’d like to know what I’m doing wrong in case I have to format it again.
nginx.conf (only the part related to Discourse and the three top settings.
     proxy_set_header X-Forwarded-Proto https;
     client_max_body_size 500M;
     proxy_set_header X-Real-IP         $remote_addr; # pass on real client's IP
server { # forumstatale.it
    server_name  forumstatale.it;
    access_log   logs/forum_statale_it.log  main;
    # pass requests for dynamic content to rails/turbogears/zope, et al
    location / {
      proxy_pass      http://app;
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/forumstatale.it/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/forumstatale.it/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
    server {
    if ($host = forumstatale.it) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen       80;
    return 404; # managed by Certbot
Thank you in advance.
Did you follow the Discourse official Standard Installation or something else?
I have used the official one (discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub). The only thing that I have skipped is the ./discourse-setup since I already had my app.yml file that was working perfectly in the previous installation. So I used ./launcher rebuild app.
thank you
You might try turning on the force https site setting.
Hi Alessandro,
Could you have restored a backup that didn’t include the uploads ? (I only ask because i did once :roll_eyes:)
You might try to upload a new file, or verify that the one of your post /var/discourse/shared/standalone/uploads/default/original/1X/895d0d7c67affaa2caff31c74bd3ef6efbf307e9.jpeg exists ?
It works but then I lose the https. (I removed it from Discourse)
I checked in the backup and there are the images I’ve uploaded.
