When I want to enter my s3 bucket name I get the following error:
s3_backup_bucket: Value doesn’t match the required format.
The bucket I use exists, it is accessible with the credentials entered in “Files” section, as mentioned in the topic. We have a bucket naming standard and conform that I need to name my bucket in the following format:
[bucket-purpose].[domainname]
So, this backup is named: community-backup.mydomain.com
I think the problem is with dots in the bucket name.
Is there any possibility to use my bucket?
A cannot change our internal standard. It is with dots. If it will not work with discourse, than I will need to find other solution to copy backups to S3 (own script).
Our naming scheme is 100% compliant with Amazon S3 Bucket Naming Requirements, so it is “relatively standard”
If discourse do not allow dots in bucket names, then I cant use its internal copy-to-s3 feature.
My question was more like: Why this restriction of using dots?
If you search ‘s3 bucket dots’ on this forum there are a few topics about it. It looks like it comes down to the lack of HTTPS support on buckets with dots in the name:
Also, this is From the same AWS Documentation page that You linked above:
When using virtual hosted–style buckets with SSL, the SSL wildcard certificate only matches buckets that do not contain periods. To work around this, use HTTP or write your own certificate verification logic. We recommend that you do not use periods (“.”) in bucket names.
So, our bucket names are valid, but will not work with amazon wildcard cert. And this is why discourse do not accept bucket names with dots.
Tank you for your help.
