Badge Granting in bulk or for a group of users
The discussion revolves around the feature request for granting badges in bulk or to a group of users in Discourse. pacharanero shared their current workaround using a Rails console code snippet to achieve this, but expressed a desire for a more user-friendly UI, such as a ‘grant badges’ interface with CSV file upload capabilities.
Mytee showed interest in the feature, while erlend_sh suggested an alternative workaround using a dedicated group with a badge query.
pacharanero corrected a code snippet from their original post. burke shared their experience of manually assigning badges and echoed the request for a multiple user selector in the admin badges page.
eviltrout pointed out the existence of a Bulk Award tool for badges, which may address the requested feature.
So far as I can see there is no facility for granting Badges in bulk except for via the SQL query in the Badge Edit / New Badge page at /admin/badges/
In my Discourse instances we award Badges to people for accolades or for attendance at certain events.
Quite often I find myself wanting to grant badges to a number of users. The group is otherwise arbitrary, ie there is nothing in Discourse’s database that could be used to decide if they should get the badge or not, so a SQL query can’t be used.
I can appreciate this is going to be a low priority feature request (as I reckon it’s maybe a bit of an edge case, and I’m not one of Discourse’s paying customers :slight_smile: ) but I thought I’d ask anyway.
A ‘grant badges’ UI which would let me add a number of users via CSV file would be awesome - something a bit like the Bulk Invite functionality would do the job.
For the time being, and to help anyone else who has the same problem, I currently grant bulk badges in the Rails console using this code:
# start with a list of emails as an array
# I prepare the list from a CSV list I am given of event attendees
# then I use Sublime Text to get it right, before pasting into the rails console)
emails = ["user1@example.com", "user2@example.com", "user3@example.com" ..... etc ]
# initialize blank array for User objects you're going to collect
userlist = []
# find emails from the list where there is a matching User in Discourse
emails.each { |e| userlist << User.try(:where, email: e) } # the use of try avoids errors when no match is found
userlist.reject!(:&empty?) # get rid of any non-matches which are an empty entry in the array
userlist.flatten! # flatten the array by one level
# BadgeGranter requires the Badge object and the User object to be passed in as parameters
# In our case we were assigning the Badge with the id number 108
userlist.each {|u| BadgeGranter.grant ( Badge.find(108), u ) }
It seems to work and so far hasn’t caused any ‘undocumented features’ or killed the DB
M
Sounds like a nice feature. Thanks for the code, and we’re also interested in having a similar feature.
Another workaround would be to create a group dedicated to a single badge, and use the “badge for all members of a group” query to give these members a badge.
Note to self: the above code should be userlist.reject!(&:empty?)
In the midst of manually assigning a couple of badges to a couple dozen people and missing a “list of people you want to grant this badge to” multiple user selector (+ optional reason) in the /admin/badges page for a badge. I know this is an old feature request, but wanted to acknowledge that I was looking for this feature today.
There is now a Bulk Award tool for badges that might help you out.
