Badges for ‘post in specific category’ and ‘filled in bio fields’
User @mikechristopher is seeking help in creating badges for two specific conditions: posting in a particular category and filling in specific bio fields.
@pfaffman provides a query to check if a post has been made in a specific category with a particular tag:
SELECT p.user_id, min(p.created_at) granted_at, MIN(p.id) post_id
FROM badge_posts p
JOIN topics t ON t.id = p.topic_id
JOIN topic_custom_fields tcf on t.id = tcf.topic_id
WHERE category_id = ANY (
SELECT id FROM categories WHERE name ilike 'CATEGORY-NAME'
) AND p.post_number = 1
AND tcf.name LIKE 'tags' and tcf.value LIKE 'TAG-NAME'
and (:backfill OR ( p.id IN (:post_ids) ))
GROUP BY p.user_id
@mikechristopher then shares his attempt to create a query for the second condition (filled in bio fields), but faces issues. @pfaffman provides a corrected query:
SELECT u.id user_id, current_timestamp granted_at
FROM users u
JOIN user_profiles up on u.id = up.user_id
WHERE bio_raw IS NOT NULL AND LENGTH(TRIM(bio_raw)) > 10 AND
uploaded_avatar_id IS NOT NULL AND
up.location IS NOT NULL AND
(:backfill OR u.id IN (:user_ids) )
@mikechristopher also asks about merging three queries into one to grant a badge if each condition is met. @pfaffman suggests that the second query is the most important one and provides a modified version that includes location and bio requirements.
The :backfill parameter is used in queries that target posts, but @pfaffman is unsure of its exact purpose.
This matches if a post with a particular tag has been posted in a particular category. You can remove the AND tcf.name ... line 3 from the bottom if you don’t care about tags.
FROM badge_posts p
GROUP BY p.user_id
Need some feedback please - would it be better to run the following 3 queries seperately to create badges and then check those badges have been granted to grant a seperate badge again. Or could someone please assist me in merging these 3 queries into 1 in order to have it grant a badge if each part of it has been done.
Thanks,
SELECT user_id, 0 post_id, current_timestamp granted_at
FROM badge_posts bp
INNER JOIN user_profiles up
WHERE (:backfill OR user_id IN (:user_ids) OR 0 NOT IN (:post_ids) )
GROUP BY user_id
HAVING count(*) > 5
SELECT user_id, current_timestamp granted_at
FROM user_profiles
WHERE location IS NOT NULL
FROM user_profiles
I can’t quite figure out the first query. Can you give it in English? Is that supposed to be “made 5 posts?”
The second two:
Users with a BIO and LOCATION
FROM user_profiles up
WHERE location IS NOT NULL AND
bio_raw IS NOT NULL
AND (:backfill OR up.user_id IN (:user_ids) )
This version, based on the Autobiographer badge with the location requirement added might be a bit better, though, as it checks that the bio is a certain lenght (remove the avatar requirement if you like):
FROM users u
Yeah the first one was to check that 5 posts have been made - someone posted it up earlier but was related to 1000 posts which I just modified. Thank you for providing the last one that’s exactly what I was after. It doesn’t include gravatar however does it so I can just add that in.
