Badges for posting
Since there deliberately isn’t the concept of achievements for posting, I’ve managed to implement it on ours, since we had it on our old forums and some were complain about the lack thereof.
Generic version:
SELECT user_id, 0 post_id, current_timestamp granted_at
FROM badge_posts
WHERE (:backfill OR user_id IN (:user_ids) OR 0 NOT IN (:post_ids) )
GROUP BY user_id
HAVING count(*) > 1000
Change the 1000 for whatever post limit you’re after. I’ve themed ours (due to the nature of our board) on powers of 2.
Note that this will (should) only count posts that are public (not in categories that are restricted or private messages) or otherwise unrestricted (checkbox on edit category ignoring badges)
Additionally, for our board I’ve had to exclude certain topics due to the nature of my charges:
FROM badge_posts
WHERE topic_id NOT IN (
   [elided]
) AND topic_id NOT IN (
   [elided]
) AND  (:backfill OR user_id IN (:user_ids) OR 0 NOT IN (:post_ids) )
GROUP BY user_id
HAVING count(*) >= 2048
Edit: There was a problem with my queries - post_id is apparently required when this is triggered on post-related triggers.
See
https://meta.discourse.org/t/badges-sql-problem/19295
And
Edit 2: Added :backfill
I think I have the correct trigger condition here, actually:
    :backfill OR
    user_id IN (
        SELECT trigger_post.user_id FROM posts trigger_post WHERE trigger_post.id IN (:post_ids)
You get the user id list from the list of triggered posts and filter on that.
Thanks. This is very helpful. I am also thinking about encouraging users to initiate discussions. I am messing around your query to count original posts with p.post_number = 1
여기서 이 작은 보석을 발견했습니다. 특정 카테고리의 게시글 수에 대한 자체 커스텀 배지 쿼리를 만들고 싶었습니다. 특정 카테고리 ID 조건을 포함하여 해당 카테고리 내의 게시글만 집계되도록 수정하는 방법은 무엇일까요?
여기서 특정 카테고리에 주제를 생성한 경우 배지가 수여되는 첫 번째 쿼리를 수정해야 할 것 같습니다. 차이점은 특정 카테고리의 게시글 수를 기준으로 수여한다는 점입니다.
배지 쿼리 미리 보기를 실행하면 다음과 같은 오류가 발생합니다:
There was an error with the query.  Any idea how to fix it?
Contract violation:
Query triggers on posts, but references the ':user_ids' array
