Badges toujours mal alignés
Continuing the discussion from Badges not aligned correctly:
After I checked if our forum was updated, I looked and found that the badges are still jumbled up and some texts are in weird locations.
Such as this example, the more badges are in a confusing location and the badges are still mixed up. I see this only in safari version Version 12.0.2 (13606.3.4.1.4) and only in our forum.
Are these the badges on the user profile page? I’m having a hard time reproducing the broken layout.
5 « J'aime »
It’s both the user profile and the badges page
I’ve tried a couple different Macs and iPads and I still can’t reproduce the issue on Codecombat — could you clear your cache or check the page in an incognito window? I wonder if you’re seeing the old CSS before it was fixed?
4 « J'aime »
Cleared cache, discourse updated and tried in incognito. Still see the weird layout.
Try reducing your browsers font size setting.
1 « J'aime »
Ok, tried several sizes and none are working.
Do you have a custom per-user theme enabled on your forum? Try in anonymous / incognito browser mode as well. You can also enable Discourse safe mode without any harm at all.
No, it’s the default theme. I also tried incognito as stated a few posts above. Do you mind telling me what safe mode is?
You can search for it very easily. Also @awesomerobot did you test at all widths?
2 « J'aime »
Oh thanks. I tried, and still I see the weird layout. Also got the repo steps.
Resize the window’s width to something like this, and it’ll be the normal layout.
But enlarging the width causes this.
I can’t repro by changing the width, but I did finally by adjusting my browser’s zoom level a bit.
I’ve pushed a change that should fix the problem.
8 « J'aime »
This topic was automatically closed after 14 days. New replies are no longer allowed.
