Badge-status handmatig wijzigen naar "niet toekenbaar"
I have loads of badges on my site which are automatically granted via the API when someone does something on the connected WordPress site. It works great!
However I have a few badges I need to manually grant on posts.
When I do this, allllll the badges I have set up appear in the “grantable badges” list which means lots of scrolling.
Is there a way to set a badge as being “not grantable” by admins, but keep it possible to grant via the API? That would help with management of badges.
Thanks!
I noticed that badges with SQL logic don’t appear in the list to grant, so is there a way for me to add some fake / impossible SQL logic to a badge so that it doesn’t appear in the list, but I can still grant with the API?
Have you enabled the custom badge SQL from the hidden setting? Enable Badge SQL
I have yes
If you have the box to add some SQL then I think you can try to add some impossible-to-get criteria in there and see how you get on. :+1: It’s not really what it’s intended for, but it might work out for what you need.
Maybe something like:
SELECT id user_id, created_at granted_at
FROM users
WHERE id = -1000
Make sure auto-revoke isn’t set as well, as that would strip the manually granted ones too.
I got this error:
Query triggers on users, but does not reference the ':user_ids' array
Did you pick a real user-based trigger? I left mine blank. I think ‘Update Daily’ would also work.
Ah yes, updated daily works fine, thanks. I’ll check it see if I can still grant it with the API.
Yes that all worked fine, thanks! As long as there is no downside to this fake SQL, it should be the solution I was looking for!
Since a recent update this no longer works, all badges are grantable again even if they have this impossible-to-get criteria.
Is this a bug? Will it be fixed? Or is it the new normal?
Thanks!
Ahh, I’m afraid this workaround no longer works. :cry:
There was a change a little while back:
They did reference this topic in the commit message, but unfortunately didn’t update here.
