Cela ressemble à une attaque pour moi. Comment pouvons-nous l’arrêter ? Cloudflare est une bonne option pour de tels scénarios, mais ce service n’est pas adapté à Discourse. Veuillez nous conseiller.
The problem is most likely that you have some mis-configuration that is falsely triggering the built-in free rate limiting protection.
If you don’t have a reverse proxy, do you have a whole bunch of people who are accessing your site from the same NATed IP number (e.g., a single business or university?)
if you were to use CloudFlare, you’d need to enable a template that re-writes headers so that the real IP is reported to Discourse.
If you’re running a reverse proxy you’ll need to ensure the real IP is being passed along, but you can also edit the above template to be more accommodating, not that you’ll need to if your real IP’s are being forwarded.
You can use Cloudflare as DNS and a cache for /uploads, but if any of their caching or “optimisation” features are touching the page then you’re completely unsupported here.
There are a long list of Cloudflare tweaks which break discourse in new and interesting ways.
Either way Cloudflare is a tangent, as indicated above the error being discussed is very likely due to nginx not receiving origin IPs. Let’s deal with the root cause rather than slap a bandage on a symptom.
You need to determine what’s causing the nginx rate limit to kick in. If your Discourse is correctly configured the only reason you should see that message is if there are a large number of users sat behind a single IP. Cloudflare can’t do anything to mitigate that kind of traffic either.
Discourse isn’t a website, it loads a javascript payload into the browser, putting another hop in the network path between client and server will only slow things down.
i asked a friend of i he used some kind of software to send many requests to my website, he sent like 3000 requests in 15 seconds and the problem occurred.
the thing is everybody with same software can take down our website like that.
so the idea here is how we can prevent this thing.?
That’s what is supposed to happen. If he floods the site with requests, he, and only he, gets the “Too many requests” notice so that he cannot take your site down. It is doing exactly what you want.
If you are browsing the site normally and get that 429 message you have a problem. If you are trying to crash your site and get the 429 message then you have proof that your site is protected.
Yes sir, i know that he did it because he is authorized, but how about somebody can do the same and flood the website all day long ? just to prevent us from reaching our website, what is the solution ? is this something related to server ability ?
we are using 8Gb server with 4CPUs !!
