Wat zou de beste manier zijn, native in Discourse, om een onderwerp toe te wijzen aan een gebruiker of groep op basis van wanneer een onderwerp een bepaalde tag heeft?
In a discussion titled “Best way to assign a topic based on a tag?” under the Feature category and tagged with automation, jordan-violet asked if Discourse natively supports auto-assigning topics to users or groups based on tags. awesomerobot clarified that while no native feature exists, a custom script within the automation plugin could achieve this — though such a script would need to be added by developers, not configured via the admin interface. jordan-violet noted the plugin doesn’t currently support custom scripting, leading awesomerobot to confirm a new “auto assign topic” script would need to be built. jordan-violet then suggested external automation tools as a simpler alternative and proposed a broader vision: a built-in automation platform (like n8n or Tines) allowing users to define custom automations directly in Discourse. tobiaseigen moved the thread to #feature, noting the request requires new automation functionality, and asked jordan-violet if they’d found a solution. They also endorsed the idea of a built-in automation platform as worthy of its own dedicated feature request.
I don’t think we have a native feature to accomplish this, but a custom script in the automation plugin could do it.
The plugin does not allow custom scripting though, does it?
Right, that was unclear — we’d need a new “auto assign topic” script to be added to the plugin. This is easier than writing a whole new plugin, but isn’t something that could be done through the admin interface.
Understood! I think an external automation may be an easier route then. Tangential, but it would be great if there were a common automation platform that users could build and define their own automations—built directly into Discourse. Think n8n, Tines, etc.
I shifted this over to Contribute > Feature since getting what the OP is asking for would require a new automation.
It’s been a while since you posted this @jordan-violet did you figure out how to meet your need?
This is a great idea too and worth investigating, but deserves it’s own separate Contribute > Feature topic.
