Summary: Allows users to create multiple anonymous accounts and to switch between them.
GitHub: GitHub - XertroV/better-anonymous: better features for anon users on discourse
Install: Follow the plugin installation guide.
Warning
This plugin was in-development (and tested to a point) but is currently not maintained and I have no intention of maintaining it; i.e. it’s somewhat unfinished. The features listed do work, though. If you would like to assume the maintainer-role of this plugin, you’re more than welcome. For anyone else interested in the code: it’s released under MIT but I’m basically happy to re-release it under whatever license (or public domain) if you have some preference (e.g. so an entire stack can be GPL).
Features
- Create new anonymous users on demand
- Set an anonymous user as active – this will become the anonymous account that is used for anonymous mode
- List all your anonymous users
Configuration
(No docs – I might have added something to the admin panel but can’t remember what property it was/did; in any case, there’s basically no config. mb I was planning to add a limit on the number of anon users per user but forgot.)
CHANGELOG
- initial features: create, list, and manage anon users
TODO
- There are some todos in the code
- Nonsequential anon names would be good. e.g. append 6 random characters, like
Anonymous-3hs8bv
A Slightly Related Plugin – autoadding Anonymous accounts to a group
I wrote another anon plugin prior to this: auto-add anon accounts to a group: GitHub - XertroV/cf-anon-auto-group: Discourse plugin to trigger `user.set_automatic_groups` for anons on login. It’s very simple, basically like 10 LOC all up.
