Better Documentation of tabs in Admin > Customize > CSS/HTML?
The discussion revolves around the need for better documentation of the tabs in Admin > Customize > CSS/HTML in Discourse. mackk initiated the conversation by asking for clarification on the definitions and usage of these tabs, which include CSS, Header, Top, Footer, < /head>, < /body>, and Embedded CSS. charleswalter provided a detailed explanation of each tab’s purpose, including their uses for customizing the homepage, navigation, and loading JavaScript. The conversation also touched on the differences between desktop and mobile customization options. erlend_sh suggested creating a preview feature, similar to Ionic, to make it easier to understand the effects of customizations. mackk and sam expressed appreciation for the clarification and support for the idea of improving the documentation and user experience.
Hi all – I’m curious if someone can clarify for me the tabs in Admin > Customize > CSS/HTML?
Here’s a screen shot of them:
So there’s:
  • CSS
  • Header
  • Top
  • Footer
  • < /head>
  • < /body>
  • Embedded CSS
Can someone clarify for me their definitions and usage?
I’ve successfully added the custom nav bar to my installation that I wanted, but it was mostly through trial and error and I would like to understand what this customize panel is really capable of!
Yep this is quite confusing as it exists. :frowning:
So there’s:
  • CSS - append styles to the global css document. This is where you can set homepage background, font changes, additional classes that you reference…
  • Header - appends code above the global navigation
  • Top - appends code after the global navigation header. Good for secondary nav
  • Footer - appends code before the close of the bottom div
  • < /head> - allows for additional code in the head section. This is where you can load javascript and the most powerful customizations of discourse to alter templates.
  • < /body> - appends code after everything is loaded. Could be used for additional tracking pixels.
  • Embedded CSS - if you want to load css inline. (Not really sure why this is needed, but perhaps if you are struggling to override other css, this can come in handy?)
That’s just for desktop. And then there’s a set for mobile as well.
CSS
Header
Top
Footer
Pretty much the same definitions as above, but since there’s no / head, the javascript template overrides need to be added to Header.
Maybe we could make a faux-preview of some sort, similar to Ionic:
Thank you! This is super helpful.
Yes, absolutely, something along those lines would be great.
