Hello!
How to change the html code? I did not find it in the admin panel and the folder with the files
The admin panel is empty
What HTML code are you trying to change - have you tried going to Customize in the admin panel?
From there you can add in custom HTML/CSS
This is where you can inject your own HTML - Discourse is coded in Ruby not HTML so you cannot amend the source files directly.
What is it you are trying to do?
A little to change the design, some parts to remove, this can not be done?
You can inject code before <header> and after After Header the Header and before / inside the Footer
You can also add any script links or meta tags to </head>
All custom CSS can be placed in the “CSS Tab” Common / Desktop / Mobile
As far as I can see you cannot edit the default structure, maybe one of the devs can interject if that is not true.
Most things now can be altered/removed/added using CSS/JS trickery as long as your skills are up to the challenge ![]()
It’s not just as simple as removing / changing some HTML coding though.
Have a read through the other categories such as #howto:tips-and-tricks or #plugin:theme
How to delete thead?
I suggest you start learning some css if you want to start customising things ![]()
To get you started - you could use:
thead {
display: none;
Можно ли вставить код рекламы Google Admobe между тегом ?
