Blank page after install
Hi! I’ve just installed discourse on a Debian 7 server but it throws a js error: Error: Unknown template object: function and returns a blank page. Here is my website http://discuss.ustudies.co.uk/
Any idea ?
Best regards.
Are you using the Docker install?
And you should definitely update to the latest stable version (1.3.2). You are currently using 1.2.1 which is quite old.
Nope, It doesn’t work for Debian, does it ?
Same result for the latest stable version as i tried
Docker should work on Debian too.
https://docs.docker.com/installation/debian/
There’s no official support if you install Discourse without Docker…
