I’m trying to install Discourse on CentOS 6.6 running on my VM on my local box. I’ve followed instruction on http://www.howtoinstalldiscourse.com/how-to-install-discourse-on-centos/. I got it running, but all i got is a blank page with these errors on my Chrome developer tools console:
GET http://localhost.newlum:85/assets/preload_store-df49ca825a94fb1f1c180909abe34900.js
GET http://localhost.newlum:85/assets/locales/en-4091e96b228c0c127f871d1f56ea5fa1.js
GET http://localhost.newlum:85/assets/vendor-6bf32a916dad1985b0362055d3458364.js
GET http://localhost.newlum:85/assets/application-dc2fd9818162f1ceb549f130951c1f25.js
Uncaught ReferenceError: PreloadStore is not defined(anonymous function)
Uncaught ReferenceError: Ember is not defined(anonymous function)
Uncaught ReferenceError: Discourse is not defined(anonymous function)
GET http://localhost.newlum:85/assets/browser-update-fd9405eb2b168d517a8ab2e955a292e2.js
I don’t think the js files are loaded properly, maybe some kind of permission issue, but have no idea how to fix, as I’ve never used docker or nginx. If you can give me some pointer would be great. thanks!
I doubt Docker is installed correctly.
What does docker --info and docker --version report?
[root@webtools discourse]# docker info
Containers: 1
Images: 7
Storage Driver: devicemapper
Pool Name: docker-8:3-8390243-pool
Pool Blocksize: 65.54 kB
Backing Filesystem: extfs
Data file: /dev/loop0
Metadata file: /dev/loop1
Data Space Used: 2.042 GB
Data Space Total: 107.4 GB
Metadata Space Used: 2.077 MB
Metadata Space Total: 2.147 GB
Udev Sync Supported: true
Data loop file: /var/lib/docker/devicemapper/devicemapper/data
Metadata loop file: /var/lib/docker/devicemapper/devicemapper/metadata
Library Version: 1.02.89-RHEL6 (2014-09-01)
Execution Driver: native-0.2
Kernel Version: 2.6.32-504.8.1.el6.x86_64
Operating System: <unknown>
CPUs: 2
Total Memory: 3.736 GiB
[root@webtools discourse]# docker version
Client version: 1.5.0
Client API version: 1.17
Go version (client): go1.3.3
Git commit (client): a8a31ef/1.5.0
OS/Arch (client): linux/amd64
Server version: 1.5.0
Server API version: 1.17
Go version (server): go1.3.3
Git commit (server): a8a31ef/1.5.0
Devicemapper is not supported. It’s super buggy in Docker. You need AUFS working.
Also that’s an old version of Docker, the current version is 1.6.1 or higher.
