נושאים ריקים לאחר התחברות (עוגיות Patreon)
סיכום מבוסס בינה מלאכותית
A user, donaldsoncd, reported that logged-in users on their Discourse forum see blank topics, with screenshots showing the issue persists across browsers and private windows. pfaffman suggested trying safe mode, which temporarily restored access for the admin. Arkshine identified the root cause: a deprecated $.cookie call in the Patreon plugin, incompatible with Ember 5, causing JS errors. Arkshine submitted a PR to fix it. pfaffman confirmed the issue is Patreon-related and posted about it on meta. donaldsoncd asked what steps to take next. david merged the fix and confirmed it would be live on hosted sites within 15–30 minutes. The issue is resolved for users once the update is deployed.
Hello!
My Discourse Forum is giving me trouble suddenly. When I am logged in, all topics show up as blank. For instance this one. Here’s the logged-in view:
And here’s the non-logged-in view:
I have tried logging in and out and clearing cache. Issue also happens with private browser window. Occurs on both Firefox and Chrome.
Does anyone have any tips for fixing this issue?
Did you try safe mode?
לייק 1
Hello!
From what I see on your forum, it seems there is an issue with the Patreon plugin:
Specifically here:
https://github.com/discourse/discourse-patreon/blob/main/assets/javascripts/discourse/connectors/topic-above-footer-buttons/patreon.js#L20C9-L20C17
I believe $.cookie usage has been deprecated and dropped from Discourse, and since Ember 5 is enabled, it errors directly. :thinking:
I don’t have an immediate solution for you; the plugin needs to fix this.
EDIT: Made a PR:
https://github.com/discourse/discourse-patreon/pull/131
4 לייקים
Thank you! This allows me to see topics and respond again as a logged-in admin. I’m not technically savvy enough to use it to troubleshoot and fix the issue though.
לייק 1
You can disable all theme components and add them back to see which one is the issue. Oh, it’s pretty clear that it’s patreon, I think, so I made a post over there: Discourse Patreon - #180 by pfaffman
לייק 1
Thanks @pfaffman and @Arkshine. It looks like you’ve find the issue and have created a fix.
Please let me know if I need to do anything on my site to get the fix applied on my installation. I tried refreshing the Patreon plug-in, but to no avail.
לייק 1
I just merged the fix from @Arkshine :clap:
@donaldsoncd this will be live on your hosted site in the next 15-30 minutes. If you’re still seeing issues after that please let us know.
5 לייקים
This topic was automatically closed after 18 hours. New replies are no longer allowed.
