Block-style spoiler tags
Need support for [spoiler] tags which are actually misnamed and are actually collapsed-block tags? Look no further!
(yes, this is basically the same as the built-in [details] block, you should try to convince your users to use those instead!)
https://github.com/lukegb/discourse-bbcode-spoiler
Screenshots
(FLARD is an injoke on my forum)
Syntax
[spoiler]contents go here[/spoiler] if you want the default title.
[spoiler=Button title]contents go here[/spoiler] if you don’t.
Features
  • Fully supports nested [spoiler] tags and markdown (so HRs, headers, etc, work fine)
  • Removes the spoiler contents from emails which are sent. (This needs rethinking, but for my usecase it’s OK since we don’t have reply-via-email turned on yet)
  • Always shows in expanded mode in post previews to allow for easier editing
  • Configurable default spoiler text (i.e. what happens if no button override text is specified)
Known issues
  • Currently recursively invokes the full Markdown->JsonML transpiler instead of letting Discourse pass me the inner JsonML. It (Discourse) seems to have weird issues with block-level Markdown tags at the moment, but that could just be me messing up.
  • Horrific UUID generation stuff in order to easily refer to the checkbox.
  • Currently overrides [spoiler] and not [hide] and this is not configurable (at the moment). PRs welcome, but I’m planning to come back to this in a bit.
  • Probably(?) doesn’t scroll properly in preview mode.
6 Curtiram
On line 58, I think you can use this.toTree(inner) instead - discourse-bbcode-spoiler/assets/javascripts/bbcode_spoiler_dialect.js at 9716d81686d0ef728409be53fce545a37cd9224e · lukegb/discourse-bbcode-spoiler · GitHub
2 Curtiram
One issue I’ve encountered: block spoilers cannot read links that are outside of the block spoiler, which makes it difficult to use them for organization as a collapsible text feature. You can manually move the links, yes, but adding new ones moves them all back to the bottom of the post.
Yeah, I know about this one. The workaround is to use non-ref style links, but it’s a bit of a pain since the Markdown editor uses them by default.
Marcado como #plugin:broken-plugin. Toda a funcionalidade, exceto o tema CSS para desenhar uma caixa ao redor dos detalhes colapsados, agora é integrada.
Se você acha que precisa disso para uma importação/migração, tente fazer o seguinte:
rake posts:remap'[\[spoiler\],\[details=Spoiler\]]'
rake posts:remap'[\[spoiler=,\[details=]'
rake posts:remap'[\[/spoiler\],\[/details\]]'
3 Curtiram
