I’d like to implement BlockAdBlock on my Discourse installation. I’ve tried using the official ad-plugin, but I guess it’s not how it works.
Any help would be greatly appreciated ! If anyone has ever managed to make it, of course.
Are you using the free script? BlockAdBlock | Stop Losing Ad Revenue
Just add the script on your /admin/customize/themes/ and select /body to add the script.
Did you try?
Alright, I didn’t even know it worked this way.
Anyways, I’m a bit confused, I don’t see any “Body” option in the admin theme menu.
And also thank you for your help c:
Well, let’s do it step by step
</body> tagOk, so all I need to do is to add the code between the <body></body> tags ?
I’ll try that naw >w< thanks for the help ~
EDIT : Ok, it works now ! But it looks like the ACCESS WEBSITE button doesn’t close the BlockAdBlock screen.
That’s a problem with the script, discourse works fine. Just contact the script’s support. ![]()
