Discorso avviato prima di configurare l'email
Well… I’ve been trying to figure out what’s going on with my instance and emails not working until I saw this:
If you do not properly configure email before bootstrapping YOU WILL HAVE A BROKEN SITE!
I have a broken site. What should I do to fix this? I’m totally fine with re-installing Discourse, but I’m not sure whats the best way to go about doing that. This is my first time working with an Ubuntu instance and ssh access.
Edit the app.yml file and bootstrap again using launcher.
I ended up using ./launcher rebuild app which did the trick. Thanks for all the help, Jeff.
I may be a noob, but now I’m a smarter noob.
