שברתי את מערכות הכניסה
Hi,
I added some JQuery lines of code and I cannot even get the login dialogue to appear anymore. How do I revert the customization so I can sign in again?
These are the lines of code I added:
https://ajax.googleapis.com/ajax/libs/jqueryui/1.10.3/themes/smoothness/jquery-ui.css
https://ajax.googleapis.com/ajax/libs/jquery/2.0.2/jquery.min.js
https://ajax.googleapis.com/ajax/libs/jqueryui/1.10.3/jquery-ui.min.js
There is a howto topic that covers how to change site settings via ssh and Ruby command line. @techapj can you recall which one?
Okay, I see that you included some incompatible JS files. Here’s how to access your instance again:
http://forum.example.com/?preview-style=none
Notice ?preview-style=none at the end of URL, it will not include your customizations. So login using that URL and remove the JS libraries you included in CSS/HTML customization.
Wow, you guys are always one step ahead. Thanks for the easy fix, really makes me want to contribute to your development!
