Continuing the discussion from Scroll position issue for topic with 1 unread post:
A recent commit broke pull down to refresh in Android Chrome.
It was working in 790c5facc946bd35f569afca3a23241c205c8693, so it’s a change in the last month.
A recent commit broke the pull-down-to-refresh feature in Android Chrome, which was previously working. awesomerobot identified the commit responsible and explained that it was intended to prevent accidental reloads on slow connections. However, Falco questioned the validity of overriding the default browser behavior, citing that it didn’t occur even with rapid scrolling on a topic with 1,700 replies. awesomerobot acknowledged that the issue may not be significant in practice and has temporarily removed the change.
ah, that was this
https://github.com/discourse/discourse/commit/5f133e20f2bf0b051006396eb03f9fed95094b29
The reasoning was that the pull to refresh feature can accidentally cause reloads when someone is scrolling up a topic on a slow connection (so the posts aren’t loading fast enough). Fine reverting this if it’s causing issues or there’s a problem with overriding the default browser behavior, it’s currently only supported by Chrome on Android anyway.
I just went to HelloForos in a topic with 1.700 replies, went to the last one, and scrolled top furiously for 400 posts or so.
I never triggered pull down to refresh.
Maybe this only happens when you are indeed in a bad connections, but I’m note sure this is a valid case to override the default browser behavior.
We have a complete valid reason to override the find shortcut and people complain all the time already.
True, the PR asking to implement it was the first I’ve heard someone complain. I was able to reproduce it on a slow connection, but I removed it for now, might not be that big of an issue in practice.
