A user encountered a broken upgrade on their Discourse forum, resulting in a generic error message and a 502 Bad Gateway after a server reboot. The issue was traced to the deprecated discourse-tagging plugin, which caused a database migration failure during the rebuild process. Community members suggested troubleshooting steps, including using safe mode, checking logs at /logs, and running discourse-doctor. The user resolved the issue by removing the problematic plugin, confirming it was the root cause. The discussion highlights the importance of plugin management and using available tools for diagnosis when upgrading self-hosted Discourse instances.
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
What notification was generated? I haven’t received any email.
The advice to post a discussion topic doesn’t make sense - the forum is down.
It would be useful to list where the error information was logged.
I couldn’t tell what broke, so I rebooted the server. Now I get 502 Bad Gateway.
If you remove all third-party plugins and rebuild, the error should go away. Once the site is up, go to /logs and see which plugin was causing the issue.
You can also try safe mode - go to your site URL with /safe-mode appended to the URL. The logs you can look for at /logs. You can also try Announcing Discourse Doctor from the command line to look for trouble. Sometimes just rebuilding a second time from the command line brings the site back up.
The message you are seeing there is intentionally unspecific so it doesn’t cause alarm for your community members or confuse them. You are right to come here to ask for guidance on troubleshooting steps - in short order you will learn them and know what to do to figure things out.
I’ll have to look up how to remove plugins. I only administer this forum once in the blue moon (thanks to the stability of Discourse).
In the meantime I tried ./launcher rebuild app which failed with an out of disk space error. After running cleanup per the prompt (14G free now), it failed with this:
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 430 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:112:in `spawn’
exec failed with the params {“cd”=>“$home”, “hook”=>“db_migrate”, “cmd”=>[“su discourse -c ‘bundle exec rake db:migrate’”]}
aa028fe633a223429da4368d3e6339a75329cdb0465361804372bc54b4fc8f35
/var/www/discourse/plugins/discourse-tagging/plugin.rb:13:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:430:in `block in notify_after_initialize'
Be sure to remove the discourse-tagging plugin ASAP. This plugin was deprecated about 3-4 years ago when we moved the functionality to core.
./discours-doctor seems to be having a syntax error:
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Would you like to serve a publicly available version of this file? (Y/n)
./discourse-doctor: line 320: [: ==: unary operator expected
Publicly available log not generated.
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
