Bug: Livestream mixed content warning causing Onebox not to render
For example:
(not working here, because, I guess livestream is not in the whitelist )
And the odd thing is, onebox is rendering in preview, but once you hit New Topic, it doesn’t work.
Using 1.3.0beta1
It looks like livestream doesn’t support HTTPS? When I change that URL to HTTPS it just redirects back. So if you are using HTTPS on a discourse, you will get a mixed content warning.
Yes. That’s exactly what I’m getting since we have HTTPS on.
Any suggested workarounds? Or does this require some extended handling in onebox?
I don’t think it’s possible to fix unless livestream adds HTTPS support.
They have support for HTTPS - but their Canonical redirects are messed up.
I just added support for Livestream via forced HTTPS to onebox in master:
^^^ It looks like the preview image gives a mixed content warning but once the video is rendered it goes away. That should be OK for most people as only the poster will see the warning briefly.
