Build and Run on different machine?
I want to build in machineA , then commit Docker image , run it on machineB .
MachineB in China, there are many network error when build on machineB.
So I want to build it on HK machineA,then run it on machineB
You can do that.
Bootstrap the image
Push to a repo
Launch it
There is a launcher command that will give you the docker command to start the container. (It’s ./launcher start-cmd)
You still need to do stuff like precompile assets and migrate the database.
I got it.Thanks dude.
