Falla la compilación en el nuevo host
He copiado todo /var/discourse a un nuevo host. Actualicé el CNAME y SSL, todo funciona bien. Cuando intento reconstruir, me encuentro con un problema que no puedo resolver.
 sudo ./launcher rebuild app
I, [2022-03-11T16:50:42.832830 #1]  INFO -- :
I, [2022-03-11T16:50:42.833980 #1]  INFO -- : Reemplazando pid /run/nginx.pid; con daemon off; en /etc/nginx/nginx.conf
I, [2022-03-11T16:50:42.834524 #1]  INFO -- : Reemplazando (?m-ix:upstream[^\\}]+\\}) con upstream discourse { server 127.0.0.1:3000; } en /etc/nginx/conf.d/discourse.conf
I, [2022-03-11T16:50:42.834854 #1]  INFO -- : Reemplazando (?-mix:server_name.+$) con server_name _ ; en /etc/nginx/conf.d/discourse.conf
I, [2022-03-11T16:50:42.835184 #1]  INFO -- : Reemplazando (?-mix:client_max_body_size.+$) con client_max_body_size $upload_size ; en /etc/nginx/conf.d/discourse.conf
I, [2022-03-11T16:50:42.835501 #1]  INFO -- : Reemplazando (?-mix:worker_connections.+$) con worker_connections $nginx_worker_connections ; en /etc/nginx/nginx.conf
I, [2022-03-11T16:50:42.835804 #1]  INFO -- : > echo "done configuring web"
I, [2022-03-11T16:50:42.839749 #1]  INFO -- : done configuring web
I, [2022-03-11T16:50:42.840160 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
ERROR:  Could not find a valid gem 'bundler' (= 2.3.4), here is why:
          Unable to download data from https://rubygems.org/ - Net::OpenTimeout: execution expired (https://rubygems.org/specs.4.8.gz)
I, [2022-03-11T16:55:43.338723 #1]  INFO -- :
I, [2022-03-11T16:55:43.339140 #1]  INFO -- : Terminating async processes
I, [2022-03-11T16:55:43.339338 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2022-03-11T16:55:43.339402 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
2022-03-11 16:55:43.339 UTC [42] LOG:  received fast shutdown request
103:signal-handler (1647017743) Received SIGTERM scheduling shutdown...
2022-03-11 16:55:43.340 UTC [42] LOG:  aborting any active transactions
2022-03-11 16:55:43.342 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-03-11 16:55:43.346 UTC [46] LOG:  shutting down
2022-03-11 16:55:43.361 UTC [42] LOG:  database system is shut down
103:M 11 Mar 2022 16:55:43.363 # User requested shutdown...
103:M 11 Mar 2022 16:55:43.363 * Saving the final RDB snapshot before exiting.
103:M 11 Mar 2022 16:55:43.433 * DB saved on disk
103:M 11 Mar 2022 16:55:43.434 # Redis is now ready to exit, bye bye...
Un wget de rubygems funciona bien, la conectividad a Internet está bien. ¿Alguna sugerencia?
Si la conectividad a Internet funciona en el host, debe depurar la conectividad a Internet dentro de los contenedores de Docker en ese host.
Encontré mi problema. Tengo IPv6 habilitado en Docker, lo que parece confundir las cosas.
Tuve que desactivarlo y luego recargar Docker.
  "ipv6": false,
  "fixed-cidr-v6": "2001:db8:1::/64"
¡Gracias por la ayuda!
Más específicamente: tenías IPv6 habilitado y configurado para asignar direcciones que no regresarán a tus contenedores.
No todas las aplicaciones están escritas para recurrir a v4 si la conectividad v6 está rota.
