Rebuild failing due to wonky ipv6
Trying to resolve my Patreon problem I’m doing a rebuild. I have only official plugins, and it’s failing with
I, [2019-05-19T22:35:13.979327 #15]  INFO -- : > cd /var/www/discourse && gem update bundler
ERROR:  While executing gem ... (Gem::RemoteFetcher::UnknownHostError)
    timed out (https://rubygems.org/specs.4.8.gz)
I, [2019-05-19T22:36:14.620134 #15]  INFO -- :
I’m sorta stumped.
I also encountered the same problem.
if use verison: beta canot rebuild, only use tests-passed
Thanks, but I’m on tests-passed.
If you’ve upgraded to tests-passed you also can’t swap back to beta until beta catches up.
It can’t hurt to disable official plugins too, just to troubleshoot.
Good idea, but no joy. I removed all plugins, and it’s still failing with
I, [2019-05-19T23:53:44.891357 #14]  INFO -- : > cd /var/www/discourse && gem update bundler
I tried upgrading Docker and disabling IPv6. Still no joy.
Ok, and if you ping www.google.com does it resolve?
What result do you get if you nslookup ? Does the connection to DNS time out?
Well, in the existing container, I can curl https://rubygems.org/specs.4.8.gz without any problem.
I guess I’ll next see if I can crank up the latest discourse/base image and see what it’s doing.
Well, a while back I enabled ipv6, and something with that broke some stuff (but only some?) inside Docker containers. I turned off those IPv6 addresses and it seems that this and my other problem are resolved.
