Hola a todos, ¿cómo cambian el color predeterminado naranja del botón?
He cambiado el color al código hexadecimal deseado en Configuración > Personalizar > Colores, pero los botones siguen siendo el naranja predeterminado.
Can you include a screenshot of the button in question and your colour settings? ![]()
Yes, definitely! Just added them
Correct. You can write some simple CSS.
Navigate to your active theme at /admin/customize/themes/ and customise the CSS.
Adding this rule will make them green.
.nav-pills li.active a, .nav-pills li a.active {
color: #fff;
background-color: #090;
Fantastic, it worked like a charm.
THANKS!!
