Hello, I need to hide an admin user from the staff list.
I don’t like that he shows in /about
section.
How could I do that?
section.
I suppose if you wanted, you could just target the div for that admin on the /about page and set it to display:none
in your admin/customize CSS. It seems to work on meta using Chrome’s inspector, at least.
I’ll admit I’m a bit curious as to why you want a secret admin, though.
In this case, I’ve got an investor that want to “see” how this site is going, but now he want to “disappear”
I’m thinking in change the username and put something like: “Secret admin”
About CSS, I don’t know how to set up that customization, sorry for my ignorance.
Regards!
Sorry, just went through and double checked with an actual customization, I don’t think applying a CSS rule will be enough since the div ids are, I guess, generated by ember, and are in any case not constant. Maybe there’s something you can do with javascript? Would have to ask someone else though, unfortunately.
What I get for writing out a quick solution without paying enough attention.
I don’t know that there’s a setting for what you’re looking for, renaming the user to something innocuous would at least be the easiest thing to do.
If you’re self-hosted, this is possible with a plugin.
# plugin header here
module HideAdminNames
NAMES_TO_HIDE = %w(investordude blahblahblah).freeze
after_initialize do
class About
def admins
@admins ||= User.where(admin: true)
.where.not(id: Discourse::SYSTEM_USER_ID)
.where.not(username_lower: HideAdminNames::NAMES_TO_HIDE)
.order(:username_lower)
The div
that wraps around each admin’s information now has a data-attribute that matches their username. So you can use
.about.admins [data-username="USERNAME"] {
display: none;
to hide specific admins in that list - swap USERNAME with the username of the admin you want to hide.
