Kan ik routeAction gebruiken in glimmer single-file components?
The discussion revolves around using the routeAction helper in Glimmer single-file components. nolo initially asked if it’s possible to use routeAction in a Glimmer template file, similar to how it’s used in .hbs templates. Arkshine suggested that in Glimmer components, actions can be called directly without the need for helpers.
However, nolo clarified that the routeAction helper is useful for invoking actions that are not declared in the local scope, and asked if there’s a way to achieve this in Glimmer components. Arkshine later provided a solution that involves importing the routeAction helper and passing the router service to it, although it was noted to look “a bit hacky.”
nolo attempted to implement this solution but encountered issues. david suggested an alternative approach by importing the default export of the routeAction helper, which should work without the need to inject the router service. However, david also mentioned that the team is moving towards using “closure actions” instead of string-based actions like routeAction.
I can use the route-action helper in .hbs template files like this:
@action={{route-action "showLogin"}}
Can I use the same declaration in a glimmer template file? I tried this but it doesn’t work:
import { routeAction } from 'discourse/helpers/route-action';
{{on "click" routeAction "showLogin"}}
In a glimmer component, I believe you don’t need the helper. You can do this directly:
{{on "click" this.showLogin}}
If you need to pass arguments:
{{on "click" (fn this.showLogin <argument>)}}
It will look for the action:
@action
showLogin(<argument>, event) {}
Thank you @Arkshine! I think I understand how to pass actions in a glimmer component in general. However the route-action helper moved along the route hierarchy to invoke an action that is not declared in local scope. So you could just declare it on the component, e.g.:
{{route-action "showCreateAccount"}}
{{route-action "composePrivateMessage"}}
I could just work on the template, care less about the invoked logic because it’s auto-magically passed in (from my point of view :). Which I liked, but I don’t understand if that was ever best practice and if/how I would have access to that now in a glimmer component.
You’re right; my bad. :pensive: I answered automatically without much thought. (well, It was 5 am :smile:).
I don’t have the answer to your question right now, but I’ll get back to you If I figure out something on my side!
From my test, the following works.
import { get } from "@ember/object";
{{on "click" (routeAction "showLogin" (get this "router._router"))}}
It assumes you have the router service defined in the component.
I’m unsure whether it’s considered bad practice. It doesn’t sound like a good idea, but it works. :smile:
Thanks again! I agree it looks a bit hacky :smile: Though it also doesn’t work for me.. trying to replace the action in discourse-featured-lists/javascripts/discourse/components/featured-list.gjs at main · nolosb/discourse-featured-lists · GitHub
Well, I might just drop it for now, the component works fine as it is. Just trying to understand a bit better how some of the stuff works under the hood :mechanic:t4:
I think if you use the default export, it should work as expected (i.e. without needing to inject the router service, or manually pass in a reference to it)
import routeAction from "discourse/helpers/route-action";
(not sure why there is also an internal function exported as routeAction… pretty confusing! Let’s fix that)
Although I would say… in general we are trying to move towards ‘closure actions’ like {{on "click" this.someFunction}} rather than string-based things like {{action "blah"}} or {{routeAction "blah"}}.
