I’ve attempted this a few times, my wordpress sometimes seems to have cache issues where things don’t update quick so I’ve guessed it was that,
I believe I’ve set everything up correct but never discount operator error
The link is present
https://blog.full30.com/wp-login.php
The secret is set and confirmed the same many times
But I only get
Is there some newbie mistake I’m making?
Thanks in advance
simon
April 29, 2023, 6:57pm
For the discourse connect provider secrets setting, try using a wildcard symbol (*) instead of using your blog’s domain. That might fix the issue. The domain you have entered looks correct to me though.
Awesome,
This alone works, thank you for that
system
(system)
Closed
May 29, 2023, 8:07pm
4
