Can someone please explain to me how the User Card pop-up works?
סיכום מבוסס בינה מלאכותית
The discussion revolves around understanding how the User Card pop-up works in Discourse. merefield is trying to figure out the code behind the User Card and how it creates a pop-up instead of linking directly to the user’s profile. gdpelican points to card-contents-base.js.es6 as the relevant code, which defines events that trigger the _show method.
merefield acknowledges the help, but is still trying to understand the code. merefield clarifies that the goal is to create a plugin with similar behavior.
Five years later, jimkleiber chimes in with a similar question, trying to modify the User Map in the Locations plugin to show the profile card instead of linking directly to the profile page. merefield admits to not remembering the solution from years ago, but expresses willingness to accept a PR to the Locations plugin with the desired functionality. jimkleiber considers digging into the code and potentially submitting a PR.
Guys, i’m trying to work out how the code for User Card works.
How does it create a pop-up and then escalate to a new page?
<a href="/u/postinguser" data-user-card="postinguser" class=""><img alt="" src="/letter_avatar_proxy/v2/letter/m/bbce88/50.png" class="avatar" title="User - Frequent Poster" width="25" height="25"></a>
I can see how it is constructed from the .hbs template file, but not how the action of clicking it causes the user card to appear …
<a href="{{poster.user.path}}" data-user-card="{{poster.user.username}}" class="{{poster.extraClasses}}">{{avatar poster avatarTemplatePath="user.avatar_template" usernamePath="user.username" imageSize="small"}}</a>
But how does the javascript fit together?
What code is causing the user card to load instead of going to the user route?
I see:
/app/assets/javascripts/discourse/widgets/poster-name.js.es6
and specifically:
export default createWidget("poster-name", {
  tagName: "div.names.trigger-user-card",
  settings: {
    showNameAndGroup: true,
    showGlyph: true
  // TODO: Allow extensibility
  posterGlyph(attrs) {
    if (attrs.moderator) {
      return iconNode("shield", { title: I18n.t("user.moderator_tooltip") });
  userLink(attrs, text) {
    return h(
      "a",
        attributes: {
          href: attrs.usernameUrl,
          "data-user-card": attrs.username
      formatUsername(text)
  html(attrs) {
    const username = attrs.username;
    const name = attrs.name;
    const nameFirst =
      this.siteSettings.display_name_on_posts &&
      !this.siteSettings.prioritize_username_in_ux &&
      name &&
      name.trim().length > 0;
    const classNames = nameFirst
      ? ["first", "full-name"]
      : ["first", "username"];
    if (attrs.staff) {
      classNames.push("staff");
    if (attrs.admin) {
      classNames.push("admin");
      classNames.push("moderator");
    if (attrs.new_user) {
      classNames.push("new-user");
    let afterNameContents =
      applyDecorators(this, "after-name", attrs, this.state) || [];
    const primaryGroupName = attrs.primary_group_name;
    if (primaryGroupName && primaryGroupName.length) {
      classNames.push(primaryGroupName);
    let nameContents = [this.userLink(attrs, nameFirst ? name : username)];
    if (this.settings.showGlyph) {
      const glyph = this.posterGlyph(attrs);
      if (glyph) {
        nameContents.push(glyph);
    nameContents = nameContents.concat(afterNameContents);
    const contents = [
      h("span", { className: classNames.join(" ") }, nameContents)
    if (!this.settings.showNameAndGroup) {
      return contents;
    if (
      name &&
      sanitizeName(name) !== sanitizeName(username)
      contents.push(
        h(
          "span.second." + (nameFirst ? "username" : "full-name"),
          [this.userLink(attrs, nameFirst ? username : name)].concat(
            afterNameContents
    const title = attrs.user_title;
    if (title && title.length) {
      contents.push(
        this.attach("poster-name-title", { title, primaryGroupName })
    return contents;
Can someone talk me through this latter code wrt to launching the user card in a state which will permit a further click to the user’s profile?
I think you’re looking for card-contents-base.js.es6, which defines a series of events which point to the _show method.
# card-contents-base.js.es6#103
$("#main-outlet").on(clickDataExpand, `[data-${id}]`, e => {});
$("#main-outlet").on(clickMention, `a.${triggeringLinkClass}`, e => {});
this.appEvents.on(previewClickEvent, $target => {});
# card-contents-base.js.es6#20
_show(username, $target) {}
Thanks James! I’ll have a read through that code … head spinning already though … :slight_smile:
What is the thing that you’re trying to do?
Trying to understand how the user card is wired in so I can ultimately code the same behaviour in a plug-in.
@merefield were you ever able to figure out how to do this?
I’m trying to figure out how to create a theme component to modify the User Map of the the Locations plugin so that when clicked, it shows the profile card instead of going directly to the profile page, but I also have no idea where to start or look.
oooh this is 5 years old … I can’t remember :sweat_smile: … I should imagine the code is very different now.
I would accept that functionality as a PR to Locations as it’s been requested before plenty of times.
haha yes that makes sense. I may dig into it soon and then if I figure out how to PR plugins, I’ll put it up :folded_hands:t2:
