It has several hundred lines of text, most of which mean nothing. If there is an error, to most people, it looks just like the ones helpfully saying “oh, everything is great! I compressed a file!”
Is there a way to reduce the output?
Not following. The error.log
of a working new install is empty.
Ooops. Apparently I can’t pay close attention when reading on a handheld device. The nginx logs are not example of what I’m talking about.
I’m talking about when you do a ./launcher build app
there are hundreds of lines of stuff that flies by, most of which is meaningless. If there is an error in the build, you get an error at the bottom that says “Well, something went wrong. It could be anywhere in the vast number of lines that just scrolled by.”
Not really, no. Maybe search for the word “error”.
