Kunnen we "Tab" gebruiken om 4 spaties in te voeren?
The discussion explores whether the “Tab” key can be used to insert 4 spaces in Discourse, particularly for formatting text like lists. xiasummer asks if a feature similar to code editors, where Tab inserts 4 spaces, is available. JammyDodger confirms that Tab can indent text, but only after selection, and notes that Tab is used for accessibility, making it difficult to repurpose. xiasummer clarifies that this is not ideal for writing articles. JammyDodger suggests using   or a custom button, while xiasummer proposes alternatives like Ctrl+Tab or Ctrl+Space. xiasummer shares a workaround using AutoHotkey to send 4 spaces with Ctrl+Space. xiasummer later notes that in version 2.9.0.beta10, Tab now indents selected text by 2 spaces, which is close to the desired functionality.
You see, we usually have to enter “2 spaces” or “4 spaces” to make patterns,
1. x1
    1. x2
    1. x3
        1. x4
to get
  1. x1
    1. x2
    2. x3
      1. x4
We usually need this kind of spaces, do we have to allways enter 4 spaces for 4 times?
When we are coding using many kinds of editors, tab will enter 4 spaces at 1 time. Can we have this feature in discourse?
I think that may already be supported:
I found it.
But seems this feature is not quite the right thing for me.
It seems only for coding, you have to select the lines already existed then press “tab”.
But when we are writing an article, we don’t have such lines to select before we write it down.
I use   quite often to precede a first-line and provide shape to some text, though there is a way you could add an indent wrap if that’s more what you’re after (maybe even with a button in the format bar).
Tab is used for page navigation for accessibility, so I’m not sure it can be repurposed that easily.
maybe “ctrl + tab” or “ctrl + space” ?
I can certainly slide it over to Contribute > UX for consideration. :+1:
I found a method.
We can use “AutoHotkey”
then use the script below, “ctrl+space” will send 4 spaces to the editor.
^space:: send {space 4}
return
But, is there a better way?
Great, it works!
In the newest version 2.9.0.beta10, I found it working to select text and enter “Tab” to move the selected text to the right with 2 spaces.
