If we use the default atlassian ID, Is there any possiblity that can we login to discourse using it at all?
That might be possible with the Discourse Open ID Connect plugin as this documentation suggests the standard is supported by Atlassian on certain products:
See OpenID Connect for Atlassian Data Center applications | Atlassian Support | Atlassian Documentation
And
