如何设置 Discourse 与 Atricore Josso CE
Hello.
I have existing running Java applications say “App1” and “App2” which runs on Tomcat7 [Execution Environment] and had implemented SSO using Atricore JOSSO CE [SAML Authentication]. Now I wanted to add Discourse as the third Application.
So, how I can set-up Discourse with JOSSO.
I’m not familiar with Josso, but taking a quick look at their website (http://www.josso.org/architecture.html)
Example Identity Capabilities include SAML2, OpenID Connect, Integrated Windows Authentication, MFA to name a few.
I think the best solution for Discourse is to get the OpenID Connect IAM Capability set up on Josso, and then configure it with the Discourse OpenID Connect plugin
2 个赞
Thanks David, for quick reply. I will try to set-up using OpenID Provider.
