Canned Replies search field missing
I can’t test it here as I don’t have access to the feature, but on hosted forums the search field for Canned Replies seems to be gone:
Previously there was a field you could type to filter the scrollable list of replies in the area I marked yellow.
(Screenshot from https://forum.ionicframework.com/)
I see it here on Meta. Please check if Canned Replies is fully up to date, you shouldn’t see excerpts anymore.
「いいね!」 2
It is a hosted community, nothing to update afaik.
I am also only a moderator :confused:
Your site is deploying now. This was previously fixed, just not deployed to your site. Should be good in the next 10-15 minutes.
「いいね!」 4
Thanks, seems to have worked:
「いいね!」 3
