Cannot add additional parameters to authorize endpoint
I have a similar question as in Format for 'openid connect authorize parameters' field.
Our Auth0 setup requires to add connection=123 to the authorize endpoint. I tried several combinations of openid connect authorize parameters without success.
So either please give me a working example or fix the bug - I have the impression that the given parameters are not routed through to the authorize request at all.
Looking at the code it looks like it needs to be in request params.
Try using chrome dev tools, track all HTTP requests, are you certain this allow listed param is in the request params? This is just used to allow list stuff, not to hardcode a value.
If you need to hardcode a value a new feature would need to be built.
I don’t get it. The parameters are not added at all…
Happened to me on one occasion, adding the parameter directly in the authorize_url seems to do the trick :thinking:
And how are you supposed to do this? The plugin only takes the discovery document:
plugins:
  openid_connect_enabled:
    default: false
  openid_connect_discovery_document:
    default: ""
  openid_connect_client_id:
    default: ""
  openid_connect_client_secret:
    default: ""
  openid_connect_rp_initiated_logout:
    default: false
  openid_connect_rp_initiated_logout_redirect:
    default: ""
  openid_connect_allow_association_change:
    default: false
  openid_connect_overrides_email:
    default: false
  openid_connect_authorize_scope:
    default: "openid"
  openid_connect_verbose_logging:
    default: false
  openid_connect_token_scope:
    default: ""
  openid_connect_error_redirects:
    default: ""
    type: list
    list_type: secret
  openid_connect_authorize_parameters:
    default: ""
    type: list
    list_type: compact
  openid_connect_claims:
    default: ""
    textarea: true
  openid_connect_match_by_email:
    default: true
I switched to the Oauth2 Basic plugin. Problem solved.
