I installed Discourse successfully and its worked perfectly with out SSL certificate. With SSL certificate I can not authenticate , its returns “Unknown error”
I can to authenticate using Google , Facebook and Twitter too.
How can I fixe this ?
As you can see, https in in use here and there is no problem logging in. So this is not a bug, but an error in the installation / configuration.
Have you double checked app.yml for errors?
Thank you for your reply , Its not working on Chrome browser Version 46.0.2490.80 (64-bit). Its working on other browsers .
Anything in the JS console (F12)?
@riking Yes I can see this error
https://SERVER_URL/message-bus/60395d0bc6a54f61b011e53e3a23c5e4/poll?dlp=t Failed to load resource: net::ERR_CONNECTION_REFUSED
https://SERVER_URL/message-bus/60395d0bc6a54f61b011e53e3a23c5e4/poll? Failed to load resource: net::ERR_NETWORK_CHANGED
application-fd188041fead0f5fd50060c9dd03bedf.js:1 Uncaught TypeError: Cannot read property 'getResponseHeader' of undefined
https://SERVER_URL/message-bus/60395d0bc6a54f61b011e53e3a23c5e4/poll? Failed to load resource: net::ERR_SPDY_PING_FAILED
https://SERVER_URL/message-bus/60395d0bc6a54f61b011e53e3a23c5e4/poll?dlp=t Failed to load resource: net::ERR_ADDRESS_UNREACHABLE
hmmm our current config uses HTTP/2 when is the last time you ran ./launcher rebuild app ?
I did it 4 hours ago
Did you do git pull before you rebuilt? That is required…
@codinghorror I just did git pull and rebuilt again . still can not authenticate on Chrome
If it is specific to a browser, sounds like an issue with your SSL cert. Where did you purchase your SSL cert from?
If you click on the failing POST /session request, what is in the “Response” tab?
SSL cert from startssl
